Rubatoguy
Dec 26, 2013Aspirant
NV+ will not boot - LED flashes
Hello, I have an NV+ with 4 2TB drives. The unit was not responding and the message on the front panel was "Spinning down..." but this remained on for over 20 minutes. I removed power and tried to res...
Dec 27, 2013Guru - Experienced User
On a two-bay duo that means it is detecting an unsupported RAID configuration (http://home.bott.ca/webserver/?p=324) I'm not sure if that carries over to the NV+ or not.
Maybe try powering down, removing disk 1, and re-booting. If that works, make/update a backup of your data before doing anything else.
