Rubatoguy
Dec 27, 2013Aspirant
NV+ will not boot - LED flashes
Hello, I have an NV+ with 4 2TB drives. The unit was not responding and the message on the front panel was "Spinning down..." but this remained on for over 20 minutes. I removed power and tried to res...
Rubatoguy
Jan 01, 2014Aspirant
For some reason my last two posts did not show up on the board.
So, I changed out the memory, and this fixed the no LCD and odd blinking light problem - but the system would still hang at the 12% FS check.
I then booted skipping the volume check and the system came up, then started a volume sync - showing that disk 2 was out of sync.
I let the synch continue all night and it is now at 93%.
If I look at the SMART status of the drives, none of them seem to show any obvious problems.
Is there something I should do once the sync is done to further test the drives?
(aside from immediately back it all up?)
thanks
Todd
thanks
Todd
