el_patron
Feb 12, 2013Tutor
NVX: temp sensor 2 out of range -116.0C/-176.8F
Hi there, hopefully I'm right here on the general questions. I have bought a NVX Pioneer Edition. I first upgraded to latest firmware 4.2.22 and installed the NAS and the discs. The first day everyt...
el_patron
Feb 12, 2013Tutor
The first upgrade was from the original factory firmaware on the NAS 4.1.9. I also had some issues to upgrade directly to 4.1.22. There several times was reported the file would be corrupted. After several tries it worked finally.
After initially upgrading to 4.1.22 I did a firmware reinstall with formatting of the disks. Do you think I should redo this again?
CORRECTION: I meant 4.2.9 and 4.2.22. Thanks to readysecure1985
