el_patron
Feb 12, 2013Tutor
NVX: temp sensor 2 out of range -116.0C/-176.8F
Hi there, hopefully I'm right here on the general questions. I have bought a NVX Pioneer Edition. I first upgraded to latest firmware 4.2.22 and installed the NAS and the discs. The first day everyt...
ReadySECURE
Feb 12, 2013Apprentice
You must be mistaken.
ReadyNAS x86 units use 4.2.x and ReadyNAS Sparc units use 4.1.x.
Generally, you wouldn't upgrade directly to 4.2.22, you would upgrade to 4.2.15>4.2.16>latest.
I would have recommended upgrading to 4.2.22 and factory defaulting the unit when you first purchased it to clear away any configs from firmwares before 4.2.22.
As you have already done this related stuff, I recommend OS reinstall on your device on 4.2.22 to see if it fixes the temperature reading.
