el_patron
Feb 12, 2013Tutor
NVX: temp sensor 2 out of range -116.0C/-176.8F
Hi there, hopefully I'm right here on the general questions. I have bought a NVX Pioneer Edition. I first upgraded to latest firmware 4.2.22 and installed the NAS and the discs. The first day everyt...
el_patron
Feb 13, 2013Tutor
readysecure1985 wrote: You must be mistaken.
ReadyNAS x86 units use 4.2.x and ReadyNAS Sparc units use 4.1.x.
yes, you are right, the original factory installed firmware was 4.2.9 and I updated to 4.2.22.
I did the OS reinstall. I will look if this will reoccur. Up to now there is only one temp sensor visible and everything seems o.K. What was strange to me last time, when plugging in the power cable, the NAS started up itself and started complaining on the mentionend "out of range" issue. I think this start up was allready unnormal. Or is this the normal behaviour?
