xcrmd's avatar
xcrmd
old firmware manually updated to newest now stuck in booting
I picked up an old ReadyNAS running firmware 6.1.9. I wasn't able to connect to the internet with it so I downloaded the latest firmware and did a manual update. I failed to see the note saying it sho...
  • Sandshark's avatar
    Feb 01, 2021
    In most cases, the warning about going backwards only means for retaining an active volume.  If you don't mind starting over, you can usually go backwards without an issue by first doing a USB recovery then a factory default without allowing the NAS to boot in between.
    But, the reason for the warnings on those specific updates is not known to me, and I can't recommend you try it.  If those updates also mess around with the U-Boot, then it's not the usual case.
