Mike-73
Jan 28, 2021Aspirant
Onedrive Backup Failure
Hello, Having a problem with One Drive, all was wroking perfectly well syncing to my file with projects and users able to work off one drive remotely, files then syncing back from one drive onto our...
- Jan 30, 2021
Hello,
Thanks for responding, i tried deleting a single project file, that didn't appear to work. I advertently i did delete the entire cloud link, this fixed it as when i tried to add just one of the folders back everything statrerd syncing once again. Thansk for your input, hope someone else reads this and it helps solving there probs. Pretty much turning off and back on :smileylol:
JohnCM_S
Jan 29, 2021NETGEAR Employee Retired
Hi Mike-73,
May I know the current firmware version of your ReadyNAS device?
Have you also tried leaving then rejoining the NAS to OneDrive?
You may also download the NAS system logs and check the one-drive.log to find some clues on what could be the cause of the issue.
- Mike-73Jan 30, 2021Aspirant
Hello,
- JohnCM_SJan 30, 2021NETGEAR Employee Retired
Hi Mike-73,
It is good to know that the OneDrive is working now. Thank you for sharing your resolution and/or workaround.:)
