Mike-73
Jan 28, 2021Aspirant
Onedrive Backup Failure
Hello, Having a problem with One Drive, all was wroking perfectly well syncing to my file with projects and users able to work off one drive remotely, files then syncing back from one drive onto our...
- Jan 30, 2021
Hello,
Thanks for responding, i tried deleting a single project file, that didn't appear to work. I advertently i did delete the entire cloud link, this fixed it as when i tried to add just one of the folders back everything statrerd syncing once again. Thansk for your input, hope someone else reads this and it helps solving there probs. Pretty much turning off and back on :smileylol:
Mike-73
Jan 30, 2021Aspirant
Hello,
JohnCM_S
Jan 30, 2021NETGEAR Employee Retired
Hi Mike-73,
It is good to know that the OneDrive is working now. Thank you for sharing your resolution and/or workaround.:)
