May 09, 2013Guru - Experienced User
OS 6.0.5 "device is offline"
I updated my RN102 from 6.0.4 to 6.0.5 about 7 hours ago, and am still seeing the "device is offline" when I access the web page, and the blinking blue light on the panel. After a while I get "Co...
evan2
May 12, 2013NETGEAR Expert
Hi Hunger,
Could you send me logs? I need to check, thanks!
if you can not open UI, could you try to do OS-Reinstall.
