JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 24, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
iscgdave
Dec 29, 2015Aspirant
I've been researching this for a client but their issues also started after upgrading to firmware 6.4.1 on RN 3130
The Antivirus is already disabled so I will try the Beta firmware.
iscgdave
Strike that, I found the firmware
- AdriFrijtersDec 29, 2015Tutor
All readers, thanks,
I downgraded to 6.4.0 and all problems were solved (thanks to the helpdesk that gave me (the dummie) manual).
I hope the next update 6.4.2 is tested before release. I am just a user without knowledge of nas or networking procedures.
Before upgrading i'll search the forum on problems.
i'd like to stick to occupational saftey, that's my expertise. So if there are questions on that subject, please ask.
Have a good and safe 2016.
Adri.
- mdgm-ntgrDec 29, 2015NETGEAR Employee Retired
Every firmware release is QA tested before release.
For the small number that encounter issues with an upgrade we look into what happened, reproduce the problems and work on fixes.
There are fixes for some issues in 6.4.2 Beta 1.
- AquaticsLiveDec 30, 2015Aspirant
So glad I found this, I was thinking the ReadyNAS had something wrong, I had updated it and forgot. Vacation and picture wanted to show the family the NAS and bam so slow it caused so many issues, I rolled it back to 6.4.0 and all was well again. I will remember to keep a copy from now on. I was so happy with the testing in the past but this clearly was lemon version.
