Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
Stanman130
Aug 07, 2014Guide
Attempting to recover a RAID 6 volume with a missing hard disk
To attempt this recovery, the configuration is the same as listed in the above entry. I just physically unplugged the ReadyNAS drive number 1 (on the motherboard SATA connector 2) to simulate a completely failed drive.
I have been attempting to use mdadm to assemble the array in a degraded mode with just the remaining 3 hard disks. So far, no luck, but here's what I found.
First, the information about the array as I collected previously:
Here is the result of information gathering about individual drives separately:
I'm only listing one drive, but the other two report in a similar fashion.
Here is the result of information gathering about the array:
After investigating how to force the array to assemble, I tried this:
Any ideas about getting this to assemble and mount up as a degraded array with one disk missing? :shock:
Since RAID 6 should allow an array to be available with up to 2 disks missing, the array should be able to mount with just one missing. The mdadm man information says to use the word "missing" in place of the device that is missing and use the command "--run" to force the assembly of the incomplete array. I tried several variants of the commands including the following (but all state the device is busy):
mdadm -- assemble --scan --run (FAILED - mdadm: No arrays found in config file or automatically)
mdadm --assemble --uuid=be4dd378:31e311ab:9af53399:976b5245 --run (FAILED - Device busy)
mdadm --assemble md127 --uuid=be4dd378:31e311ab:9af53399:976b5245 --run (FAILED - Device busy)
mdadm --assemble --uuid=be4dd378:31e311ab:9af53399:976b5245 /dev/sdd3 /dev/sdc3 /dev/sdb3 --run (FAILED - Device busy)
I'd like to find out how to do this with test data first, before I have to try it with real data at risk.
Thanks for any ideas!
- Stan
cat /proc/mdstat
Personalities:
md125 : inactive sdd1[3] (S) sdc1[2] (S) sdb1[1] (S)
12576768 blocks super 1.2
md126 : inactive sdb2[2] (S) sdd2[3] (S) sdc2[2] (S)
1572096 blocks super 1.2
md127 : inactive sdd3[3] (S) sdb3[1] (S) sdc3[2] (S)
5845994613 blocks super 1.2
unused devices: <none>
mdadm --examine /dev/sdd3
/dev/sdd3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : be4dd378:31e311ab:9af53399:976b5245
Creation Time : Sun Jul 20 07:45:00 2014
Raid Level : raid6
Raid Devices : 4
Avail Dev Size : 3897329742 (1858.39 GiB 1995.43 GB)
Array Size : 3897329408 (3716.78 GiB 3990.87 GB)
Used Dev Size : 3897329408 (1858.39 GiB 1995.43 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
Unused Space : before=262064 sectors, after=334 sectors
State : clean
Device UUID : fa36d5e1:76f3276a:e10be6e3:535a21bb
Update Time : Mon Jul 21 00:53:10 2014
Checksum : 21bec207 - correct
Events : 19
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 3
Array State : AAAA ('A' == active, '.' == missing, 'R' == replacing)
mdadm --examine /dev/sdd3 --scan
ARRAY /dev/md/TESTFLX6-0 metadata=1.2 UUID=be4dd378:31e311ab:9af53399:976b5245 name=5e276850:TESTFLX6-0
mdadm --create md127 --chunk=64 --level=raid6 --raid-devices=4 --run /dev/sdd3 /dev/sdc3 /dev/sdb3 missing --verbose
mdadm: layout defaults to left-symmetric
mdadm: super1.x cannot open /dev/sdd3: Device or resource busy
mdmon: ddf: Cannot use /dev/sdd3: Device or resource busy
mdmon: Cannot use /dev/sdd3: It is busy
mdadm: cannot open /dev/sdd3: Device or resource busy
- Stan
