CharlieA_ECTP
Sep 19, 2016Aspirant
out-of-band management options for ReadyNAS
Hello,
We are looking at mid-business type of readyNAS that can provide support for out-of-band management. We cannot find any documentation in the internet that can do so. We are aware that the new readyNAS has more than 1 LAN port. So is it possible to assign 1 of the LAN port to be used for out-of-band management sitting on another VLAN? If it's possible, please provide us documentation or screenshot on how to do so.
This is important for us to know as we want to finalize soon our NAS candidates and currently Netgear is not part of it since out-of-band management is not a significant feature of Netgear NAS devices.
Charlie
- kohdeeNETGEAR Expert
ReadyNAS provides management services on any connected address. ReadyNAS offers services like WebDAV which would require you to access the HTTP/HTTPS ports. There's no way for you to turn off management services on one NIC but not another.
ReadyNAS OS 6.6 will offer VLAN support to add multiple VLANs, but that doesn't enable/disable management per VLAN.
This feature is not in ReadyNAS because it has not been highly requested.
- mdgm-ntgrNETGEAR Employee Retired
You could post this to the Ideas Exchange if you like if it's not already there.
I agree. A built-in way to put iscsi traffic on a dedicated LAN port is related, and maybe could be done through the same mechanism.
I posted an idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Easy-way-to-dedicate-NICs-for-specific-purposes/idi-p/1141692
If this idea is of interest, please vote for it by clicking on the up-arrow icon.
You can configure the two LAN ports with different IP addresses.
The Web UI won't let you limit the use of the second LAN port to management only, and it won't let you prevent management via the first LAN port. But you can enable ssh on the NAS, and possibly configure iptables to block http access on the primary port if you wish.
Hopefully someone from Netgear - mdgm-ntgr or JennC perhaps - will connect you with Netgear Presales.
