courtier1
Jul 24, 2013Aspirant
Partial RSYNC failure or ReadyNAS bug?
I have a QNAP TurboNAS which I back up to a Netgear ReadyNAS NV+. There are four shares that I want to replicate via rsync. Both sets of folders exist on both devices. Rsync is successfully working...
Aug 12, 2013Guru - Experienced User
Might be worth trying on the qnap (using the ReadyNAS IP address).
JohnnyB wrote:
StephenB wrote: The QNAP shouldn't be seeing a list of shares that are enabled for RSYNC, as there is no way to advertise them.
If you know the server, rsync will show you all (listable) modules:
# rsync nas.local::
backup "Backup Share"
media "Media Server Share
Note that the :: at the end of the command line is needed.
