FG
Jun 15, 2018Aspirant
Performance speed while "backup" task is running
firmware 6.9.1
readynas 2120
While a backup task is running (coping from NAS to USB) the performance of the NAS take a notable drop. It takes longer to write files to NAS and longer browse/re...
Marc_V
Jun 17, 2018NETGEAR Employee Retired
Hi FG
NAS running different processes such as a backup job certainly uses resources and you might notice a slight effect on it's performance but it should not cause too much.
We can check the logs to see what really is causing the performance drop of your NAS, you can send it to us using the guide on my Sig.
Regards
