FG
Jun 15, 2018Aspirant
Performance speed while "backup" task is running
firmware 6.9.1
readynas 2120
While a backup task is running (coping from NAS to USB) the performance of the NAS take a notable drop. It takes longer to write files to NAS and longer browse/re...
Marc_V
Jun 17, 2018NETGEAR Employee Retired
Hi FG
NAS running different processes such as a backup job certainly uses resources and you might notice a slight effect on it's performance but it should not cause too much.
We can check the logs to see what really is causing the performance drop of your NAS, you can send it to us using the guide on my Sig.
Regards
FG
Jun 18, 2018Aspirant
Log files were just sent
Time in question was Friday the 15th.
- Marc_VJun 20, 2018NETGEAR Employee Retired
Hi FG
Have you enabled quotas? How ofthen do you take snapshots? You may try to disable quotas and see if you can reduce the snapshot frequency. You might be experiencing the slow performance due to this, also your data volume should be below 85% full, if ever it gets to that point it is always advised to free up space to eliminate performance issues.
Hope this helps
Regards
- FGJun 20, 2018Aspirant
Quotas are enabled. I have 1 share that anyone can use, but I wanted to limit how much data can go on that share.
Yes to snapshots, some are daily, some only what there is a change in the share.
The slowdown is only during a backup task.
Another problem I noticed yesterday, I recently upgraded from 6.9.1 to 6.9.3, since then when I use Chrome to go to NAS GUI it will connect to admin page breifly, then I get the "conntecting to the ReadyNAS Page..." message. Explore connects to NAS GUI just fine.
Hi FG
If you can disable Quotas, adjust snapshot schedules and run volume maintenance we might experience improived performance.
Regarding the issue after updating, you may want to try and reboot your NAS and let it sit for a few minutes while connected on the internet.
How is your data volume doing? Have you checked how full it is right now? using the logs it shows at 73% full. Hope everything's fine.
Regards
