Bornslippy
Mar 09, 2018Aspirant
Periodic "Error communicating with UPS 'UPS'" Error
This appears to have been seen in earlier firmware but I'm getting it in 6.9.2. I receive email alerts saying there is a problem then immediately another message saying its ok again. Happens a fe...
Marc_V
Mar 11, 2018NETGEAR Employee Retired
Hi Bornslippy
Did you had the same issue on your previous UPS? If not have you tried updating your firmware to the latest? OS 6.9.3
It should have been resolved on OS 6.8.1 but it would be better if you can update your firmware.
You may also want to test a different UPS if possible but hopefully refreshing the firmware can resolve it.
Regards
- BornslippyMar 12, 2018Aspirant
Hi Marc
I haven't tried 6.9.3 as I am set to the "stable" updates track. Is that n-1?
I've checked the email alert log and these issues also occurred with the previous example of the device as far back as August. I replaced the UPS in January. I assume that the errors came in with the 6.8.0 firmware update and were NOT fixed by subsequent updates. Sorry - don't know which updates I applied when as I cleared the logs, but I assume it was all "stable" updates - I have email log messages which show the system has rebooted every month since then, some of which were presumably because of firmware updates.
Can you confirm that there was a regression which is fixed in 6.9.3 ? I'm reluctant to just install it on the offchance that it might finally fix the problem...
- Marc_VMar 12, 2018NETGEAR Employee Retired
The issue should have been fixed from the previous stable firmwares. 6.9.3 is already on the update servers and should be detected by your NAS. It is better to update to the latest and see if you will still have the issue. Have you tried using a different Brand or model of UPS?
- StephenBMar 12, 2018Guru - Experienced User
FWIW, I had similar issues with a different Cyberpower UPS model some time ago, but I am not seeing them with the current firmware.
