Dinky's avatar
Dinky
Follower
Feb 09, 2011
Playlists help
Hi,
So far I'm really impressed with my Duo - it's all working well. Only one thing I can't get it to do!
I cannot get it to pick up playlists I create. This is the process I go through:
Export a playlist from iTunes as an m3u
Copy it into my music directory on the Duo
Change the path of the files to be correct.
What I have done now is created a small music directory - 1 album - and put a playlist in there, so that I can rescan quickly and try to get the playlist picked up.
I've checked the syntax in the m3u but it seems fine.
Here is the playlist:
#EXTM3U
#EXTINF:523,Elements - Lemon Jelly
./Lemon Jelly/Lost Horizons/01 Elements.m4a
It's called Evening.m3u, and sits at the same level as the music folder.
Can anyone help? Is there anything obvious I'm doing wrong? I've played around with this a lot, ie changing the pathname to be absolute, changing the location, creating a Playlists folder, but none of it seems to work.
Is there any way to run this under debug so that I can see the parse problems?
I am using a Pure Avanti Flow and VLC on a Mac - both with the same results.
Cheers
Dinky
ProSupport for Business
