ricster
Jun 17, 2012Aspirant
Please help. CASE #18791951
Hi, i've updated to 4.2.20 because I was having an issue when creating, it gave an error no space left on device. I can go into tmp and mkdir test2 and it gives that error. I've tried update remote...
ricster
Jun 18, 2012Aspirant
Managed to get the syslog
Jun 18 20:27:08 nas-C1-4F-BC kernel: ata1.00: status: { DRDY ERR }
Jun 18 20:27:08 nas-C1-4F-BC kernel: ata1.00: error: { UNC }
Jun 18 20:27:08 nas-C1-4F-BC kernel: ata1.00: configured for UDMA/133
Jun 18 20:27:08 nas-C1-4F-BC kernel: sd 0:0:0:0: [sda] Unhandled sense code
Jun 18 20:27:08 nas-C1-4F-BC kernel: sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Jun 18 20:27:08 nas-C1-4F-BC kernel: sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
Jun 18 20:27:08 nas-C1-4F-BC kernel: Descriptor sense data with sense descriptors (in hex):
Jun 18 20:27:08 nas-C1-4F-BC kernel: 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Jun 18 20:27:08 nas-C1-4F-BC kernel: 00 94 4d 90
Jun 18 20:27:08 nas-C1-4F-BC kernel: sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
Jun 18 20:27:08 nas-C1-4F-BC kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 94 4d 90 00 00 08 00
Jun 18 20:27:08 nas-C1-4F-BC kernel: end_request: I/O error, dev sda, sector 9719184
Jun 18 20:27:08 nas-C1-4F-BC kernel: ata1: EH complete
Jun 18 20:27:08 nas-C1-4F-BC kernel: nfsd: last server has exited, flushing export cache
Jun 18 20:27:08 nas-C1-4F-BC exiting on signal 15
Jun 18 20:30:39 nas-C1-4F-BC syslogd 1.4.1#18: restart.
Jun 18 20:30:39 nas-C1-4F-BC syslog: Kernel log daemon terminating.
Jun 18 20:30:40 nas-C1-4F-BC exportfs[2035]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:30:40 nas-C1-4F-BC exportfs[2035]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:30:40 nas-C1-4F-BC exportfs[2035]: /proc/fs/nfs/exports:1: unknown keyword "test-client-(rw"
Jun 18 20:30:40 nas-C1-4F-BC rpc.statd[2043]: Version 1.1.2 Starting
Jun 18 20:31:55 nas-C1-4F-BC syslogd 1.4.1#18: restart.
Jun 18 20:31:57 nas-C1-4F-BC ifplugd(eth0)[2526]: ifplugd 0.28 initializing.
Jun 18 20:31:57 nas-C1-4F-BC ifplugd(eth0)[2526]: Using interface eth0/A0:21:B7:C1:4F:BC with driver <sk98lin> (version: 10.70.1.3 (01))
Jun 18 20:31:57 nas-C1-4F-BC ifplugd(eth0)[2526]: Using detection mode: SIOCETHTOOL
Jun 18 20:31:57 nas-C1-4F-BC ifplugd(eth0)[2526]: Initialization complete, link beat not detected.
Jun 18 20:31:58 nas-C1-4F-BC ifplugd(eth1)[2550]: ifplugd 0.28 initializing.
Jun 18 20:31:58 nas-C1-4F-BC ifplugd(eth1)[2550]: Using interface eth1/A0:21:B7:C1:4F:BD with driver <sk98lin> (version: 10.70.1.3 (01))
Jun 18 20:31:58 nas-C1-4F-BC ifplugd(eth1)[2550]: Using detection mode: SIOCETHTOOL
Jun 18 20:31:58 nas-C1-4F-BC ifplugd(eth1)[2550]: Initialization complete, link beat not detected.
Jun 18 20:32:01 nas-C1-4F-BC RAIDiator: System is up.
Jun 18 20:32:01 nas-C1-4F-BC ifplugd(eth0)[2526]: Link beat detected.
Jun 18 20:32:01 nas-C1-4F-BC ifplugd(eth1)[2550]: Link beat detected.
Jun 18 20:32:02 nas-C1-4F-BC RAIDiator: USB: Waiting for USB storage lock to clear.
Jun 18 20:32:02 nas-C1-4F-BC ifplugd(eth0)[2526]: Executing '/etc/ifplugd/ifplugd.action eth0 up'.
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2804]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2804]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2804]: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2804]: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC RAIDiator: Could not open USB storage remover.
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: Executing '/etc/ifplugd/ifplugd.action eth1 up'.
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: 2794: old priority 0, new priority 0
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: 2811: old priority 0, new priority 0
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2837]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup".
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Assuming default behaviour ('no_subtree_check').
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2837]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: exportfs: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media".
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2837]: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: exportfs: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3".
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2837]: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: exportfs: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Running ntpd to synchronize clock.
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: chronyd version 1.24 starting
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2854]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup".
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: Assuming default behaviour ('no_subtree_check').
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2854]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: exportfs: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media".
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2854]: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: exportfs: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3".
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: could not open lockfile /var/run/chronyd.pid for writing
Jun 18 20:32:03 nas-C1-4F-BC exportfs[2854]: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: exportfs: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: Linux kernel major=2 minor=6 patch=37
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
Jun 18 20:32:03 nas-C1-4F-BC ifplugd(eth1)[2550]: client: Running ntpd to synchronize clock.
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: chronyd version 1.24 starting
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: could not open lockfile /var/run/chronyd.pid for writing
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2855]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: Initial txc.tick=10000 txc.freq=-1772892 (-27.05218506) txc.offset=0 => hz=100 shift_hz=7
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: Linux kernel major=2 minor=6 patch=37
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: calculated_freq_scale=1.00000000 freq_scale=1.00000000
Jun 18 20:32:03 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 20:32:04 nas-C1-4F-BC chronyd[2855]: System's initial offset : 0.051405 seconds slow of true (slew)
Jun 18 20:32:04 nas-C1-4F-BC chronyd[2871]: System's initial offset : 0.052030 seconds slow of true (slew)
Jun 18 20:32:04 nas-C1-4F-BC chronyd[2855]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:04 nas-C1-4F-BC chronyd[2871]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:05 nas-C1-4F-BC exportfs[2941]: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/backup". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:05 nas-C1-4F-BC exportfs[2941]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/media". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:05 nas-C1-4F-BC exportfs[2941]: /etc/exports [3]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_3". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:05 nas-C1-4F-BC exportfs[2941]: /etc/exports [4]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_4". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x
Jun 18 20:32:05 nas-C1-4F-BC exportfs[2941]: can't open /var/lib/nfs/etab.tmp for writing
Jun 18 20:32:05 nas-C1-4F-BC RAIDiator: Could not open USB storage remover.
Jun 18 20:32:05 nas-C1-4F-BC avahi-daemon[2949]: Found user 'avahi' (UID 20) and group 'avahi' (GID 20).
Jun 18 20:32:05 nas-C1-4F-BC avahi-daemon[2949]: Successfully dropped root privileges.
Jun 18 20:32:05 nas-C1-4F-BC avahi-daemon[2949]: avahi-daemon 0.6.23 starting up.
Jun 18 20:32:05 nas-C1-4F-BC avahi-daemon[2949]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jun 18 20:32:05 nas-C1-4F-BC avahi-daemon[2949]: bind(): No space left on device
Jun 18 20:32:05 nas-C1-4F-BC pcscd: pcscdaemon.c:464:main() pcsc-lite 1.3.2 daemon ready.
Jun 18 20:32:05 nas-C1-4F-BC pcscd: winscard_msg_srv.c:133:SHMInitializeCommonSegment() Unable to bind common socket: No space left on device
Jun 18 20:32:05 nas-C1-4F-BC pcscd: pcscdaemon.c:104:SVCServiceRunLoop() Error initializing pcscd.
Jun 18 20:32:05 nas-C1-4F-BC pcscd: pcscdaemon.c:489:at_exit() cleaning /var/run
Jun 18 20:32:05 nas-C1-4F-BC pcscd: pcscdaemon.c:508:clean_temp_files() Cannot unlink /var/run/pcscd.comm: No such file or directory
Jun 18 20:32:05 nas-C1-4F-BC chronyd[2855]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:05 nas-C1-4F-BC chronyd[2871]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:06 nas-C1-4F-BC chronyd[2855]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:06 nas-C1-4F-BC chronyd[2871]: Could not send to 209.249.181.23 : Bad file descriptor
Jun 18 20:32:10 nas-C1-4F-BC ifplugd(eth1)[2550]: client: Starting SABnzbd+ binary newsgrabber:.
Jun 18 20:32:10 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Starting SABnzbd+ binary newsgrabber:.
Jun 18 20:32:11 nas-C1-4F-BC ifplugd(eth1)[2550]: client: Starting SickBeard
Jun 18 20:32:11 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Starting SickBeard
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Exception in thread HTTPServer Thread-1:
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Traceback (most recent call last):
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: File "/usr/lib/python2.6/threading.py", line 532, in __bootstrap_inner
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: self.run()
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: File "/usr/lib/python2.6/threading.py", line 484, in run
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: self.__target(*self.__args, **self.__kwargs)
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: File "/c/.sickbeard/cherrypy/process/servers.py", line 75, in _start_http_thread
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: self.httpserver.start()
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: File "/c/.sickbeard/cherrypy/wsgiserver/__init__.py", line 1634, in start
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: raise socket.error(msg)
Jun 18 20:32:19 nas-C1-4F-BC ifplugd(eth0)[2526]: client: error: [Errno 98] Address already in use
Jun 18 20:32:29 nas-C1-4F-BC ifplugd(eth1)[2550]: client: PID: 3175
Jun 18 20:32:29 nas-C1-4F-BC ifplugd(eth0)[2526]: client: PID: 3176
Jun 18 20:32:30 nas-C1-4F-BC ifplugd(eth0)[2526]: client: Starting plexserver
Jun 18 20:32:30 nas-C1-4F-BC ifplugd(eth1)[2550]: client: Starting plexserver
Jun 18 20:32:30 nas-C1-4F-BC ifplugd(eth1)[2550]: client: start-stop-daemon: Unable to open pidfile `/var/run/plexserver.pid' for writing: No space left on device (No space left on device)
Jun 18 20:32:30 nas-C1-4F-BC ifplugd(eth0)[2526]: client: start-stop-daemon: Unable to open pidfile `/var/run/plexserver.pid' for writing: No space left on device (No space left on device)
Jun 18 20:32:35 nas-C1-4F-BC ifplugd(eth0)[2526]: Program executed successfully.
Jun 18 20:49:11 nas-C1-4F-BC chronyd[2871]: Selected source 209.249.181.23
Jun 18 20:49:11 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 20:53:27 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 21:01:59 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 21:10:31 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 21:19:03 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 21:27:36 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
Jun 18 21:31:52 nas-C1-4F-BC chronyd[2871]: Could not open temporary driftfile /var/lib/chrony/chrony.drift.tmp for writing
