ricster
Jun 17, 2012Aspirant
Please help. CASE #18791951
Hi, i've updated to 4.2.20 because I was having an issue when creating, it gave an error no space left on device. I can go into tmp and mkdir test2 and it gives that error. I've tried update remote...
dsm1212
Jun 18, 2012Apprentice
Total WAG: I see you are running plex. You didn't delete the link /root/Library did you? If you did, then the next time you start plex it will recreate the plex library on your / partition at this location quickly filling it up. /root/Library needs to be a soft link to /c/.plex/Library.
