ricster's avatar
ricster
Please help. CASE #18791951
Hi, i've updated to 4.2.20 because I was having an issue when creating, it gave an error no space left on device. I can go into tmp and mkdir test2 and it gives that error.
I've tried update remote and it gives error error connecting to remote server.
I have only used 30% out of 2TB. Thanks for help.
  • amac27 wrote:
    I've checked the case and seems that support has already taken care of the issue.
    it seems that there are lot of small files that is written in the root folder.
    HI, ive not heard anything back yet. the unit is still in telnet mode. I havent touched it.
    Were the files left over from a bad firmware install do you know? or was it plex gone wrong?
    Cheers
  • The files where in /tmp/cw folder i'm not sure which add-on uses this but we've moved it to /c/.tmp/cw folder.
    since you have root ssh you can maybe create a soft link to /c/.tmp/cw.
    You can now boot the NAS to normal mode
ProSupport for Business
