Herodotus
Nov 11, 2012Aspirant
Please Help with a ReadyNAS X6
I'm a tech novice. This is all foreign to me. I have a ReadyNAS X6 (From the box: RNX6-DLS, if that matters) that I haven't touched in about four years. Back then, I vaguely remember RAIDar informe...
Nov 21, 2012Guru - Experienced User
They won't show up under computer, however the windows disk manager utility (control panel) should see them, and lifeguard should find them.
Herodotus wrote:
mdgm wrote: Could you hook up your Western Digital disks to an internal SATA port in your PC and check hem using WD LifeGuard Diagnostics?
We tried that, but none of the disks showed up.
Anything else we can do?
Thanks!
