jpickell
Nov 26, 2013Aspirant
Please Help!
I have 400K+ photos backed up on my ReadyNas. I switched over the a Mac Air about a year ago and figured out how to connect the Air via AFP. A few months ago I replaced my wireless modem with a std mo...
Nov 26, 2013Guru - Experienced User
Did you have a static IP address configured on the ReadyNAS? That is the usual cause for this problem.
If so, you can do an OS reinstall on the NAS - which would reset the admin password to the default value, and reset the IP configuration to DHCP.
There are a couple other methods you could use, but they are simpler if you have an ethernet connection for the PC.
