Omaha2002
Jul 09, 2013Tutor
Poor NFS performance OS 6 Readynas pro (Solved with 6.1.1)
(edit) turned out I was testing the local disk because the NFS share wasn't mounted. So still investigating poor NFS performance on OS6 I've installed OS6 on a Readynas Pro, so far everything wor...
Omaha2002
Jul 09, 2013Tutor
Yep, you are absolutely right, I was just logging in to delete the post or at least update it. turned out the NFS share wasn't mounted so I was testing local disc. So I'm still left with very poor performance with NFS on OS6.
