Omaha2002
Jul 09, 2013Tutor
Poor NFS performance OS 6 Readynas pro (Solved with 6.1.1)
(edit) turned out I was testing the local disk because the NFS share wasn't mounted. So still investigating poor NFS performance on OS6 I've installed OS6 on a Readynas Pro, so far everything wor...
Omaha2002
Aug 31, 2013Tutor
Updating to 6.1.1 results in much better NFS performance, with 6.0.8 I got 64Mb/sec writing, now with 6.1.1 (using async):
root@Meterkast:/mnt/KVM_NFS# time dd if=/dev/zero of=/mnt/KVM_NFS/testfile bs=256k count=16384
16384+0 records in
16384+0 records out
4294967296 bytes (4.3 GB) copied, 39.0735 s, 110 MB/s
real 0m39.985s
user 0m0.000s
sys 0m2.132s
root@Meterkast:/mnt/KVM_NFS# time dd if=/mnt/KVM_NFS/testfile of=/dev/null bs=16k
262144+0 records in
262144+0 records out
4294967296 bytes (4.3 GB) copied, 37.633 s, 114 MB/s
real 0m37.636s
user 0m0.048s
sys 0m1.824s
Very usable speeds!!
16384+0 records in
16384+0 records out
real 0m39.985s
user 0m0.000s
sys 0m2.132s
262144+0 records in
real 0m37.636s
user 0m0.048s
sys 0m1.824s
