jackburton
Mar 03, 2017Tutor
Poor Performance on ReadyNas 2120 - firmware 6.6.1
Hi all,
this is the result of a test with Nas Performance Tester 1.7 :
NAS performance tester 1.7 http://www.808.dk/?nastester Running warmup... Running a 400MB file write on \\SITEP-NAS\Sofware 5 times... Iteration 1: 11,82 MB/sec Iteration 2: 11,83 MB/sec Iteration 3: 11,67 MB/sec Iteration 4: 11,75 MB/sec Iteration 5: 11,82 MB/sec ----------------------------- Average (W): 11,78 MB/sec ----------------------------- Running a 400MB file read on \\SITEP-NAS\Sofware 5 times... Iteration 1: 11,71 MB/sec Iteration 2: 11,55 MB/sec Iteration 3: 11,55 MB/sec Iteration 4: 11,54 MB/sec Iteration 5: 10,05 MB/sec ----------------------------- Average (R): 11,28 MB/sec -----------------------------
This is my configuration:
Any help would be much appreciated.
thank you.
- Retired_MemberMar 03, 2017
Putting the address of router as dns server might help.
- Retired_Member
Disabling Antivirus might improve this to a certain degree. If already done, just ignore. 6.6.1 is known for having issues with Antivirus.
Hi,
antivirus is already disabled,
connection is gigabit,
disks installed are 4 X Seagate Constellation ES.3, tot. 4 x 2GB in RAID 5 configuration
- mdgm-ntgrNETGEAR Employee Retired
Which services are you running?
Which apps do you have installed?
Can you try disabling IPv6?
