ovidiu
Nov 14, 2016Aspirant
Pro 6 (6.6.0 beta 2 - T117) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu
Pro 6 (6.6.0 beta 2 - T117 ) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu. When I powered the NAS on it would not boot. It said ReadyNAS on the LCD, there was no link lig...
mdgm-ntgr
Nov 14, 2016NETGEAR Employee Retired
It could well be the PSU, but that is a guess.
We don't sell replacement PSUs for this, but there are suggestions on the community as to which ones you can try. You may need an extension cable for it.
The 300 series would be a step down in performance from the Pro 6. The RN516, RN526X and RN626X would be logical choices for a new NAS.
Yes you should be able to power down both systems and migrate your disks across keeping the order the same.
We don't recommend sticking on beta firmware once production firmware is available.
- ovidiuNov 15, 2016Aspirant
I see... I do not really want to toss the unit if possible, I would like to fix it.
Can you please point me on how to isolate the problem?
The small red LED1 on the motherboard is normally lit, or it is generic for a failure ?
What would you do in my place to try to revive the unit ?
and while I am at it the 500 unit would give me more bandwith ?
I am the sole user of the unit and it is used just for my DVD rips and family movies.
thank you
- StephenBNov 15, 2016Guru - Experienced User
That is normal.
The only practical steps I can think are to
(a) try the other ethernet jack
(b) try replacing the PSU
The 526X and 626x are faster than the pro, but with a single user and gigabit ethernet you are mostly limited by ethernet. If you do real-time streaming, the 526X/626X can transcode HD in real time, which is something the pro can't do.
Thank you for the input. Tried the other ethernet port. Does not show in the router DHCP table.
So the only thing left is to try and switch the PSU. I am ordering one and will update on it.
Regarding the transcoding. I never do that. Shall I ?
I use the playstation as my media server and in the very rare ocassions I watch on the TV screen I might use my worktation with Universal Media server to do the transcoding (I know there is more bandwith consumtion on the LAN) but it's OK.
In terms of reading speed from the NAS, the 300 500 and 6oo series are similar ?
I do not use any plugins or programs (like plex).
