ovidiu
Nov 14, 2016Aspirant
Pro 6 (6.6.0 beta 2 - T117) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu
Pro 6 (6.6.0 beta 2 - T117 ) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu. When I powered the NAS on it would not boot. It said ReadyNAS on the LCD, there was no link lig...
mdgm-ntgr
Nov 14, 2016NETGEAR Employee Retired
It could well be the PSU, but that is a guess.
We don't sell replacement PSUs for this, but there are suggestions on the community as to which ones you can try. You may need an extension cable for it.
The 300 series would be a step down in performance from the Pro 6. The RN516, RN526X and RN626X would be logical choices for a new NAS.
Yes you should be able to power down both systems and migrate your disks across keeping the order the same.
We don't recommend sticking on beta firmware once production firmware is available.
ovidiu
Nov 15, 2016Aspirant
I see... I do not really want to toss the unit if possible, I would like to fix it.
Can you please point me on how to isolate the problem?
The small red LED1 on the motherboard is normally lit, or it is generic for a failure ?
What would you do in my place to try to revive the unit ?
and while I am at it the 500 unit would give me more bandwith ?
I am the sole user of the unit and it is used just for my DVD rips and family movies.
thank you
