ovidiu
Nov 14, 2016Aspirant
Pro 6 (6.6.0 beta 2 - T117) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu
Pro 6 (6.6.0 beta 2 - T117 ) turning on but stuck at booting with only ReadyNAS ons panel. Boot menu. When I powered the NAS on it would not boot. It said ReadyNAS on the LCD, there was no link lig...
btaroli
Dec 01, 2016Prodigy
One thing to consider is that PLEX more recently added a feature that enables to to pre-transcode new media so that it can be direct played to various devices. So a NAS without the grunt to live-transcode can still get the job done in the background, if you don't mind waiting for the conversion -- sort of the same way it handles syncing.
- StephenBDec 01, 2016Guru - Experienced User
Yes. And though it takes space on the NAS, the converted media usually quite a bit smaller than the original.
- ovidiuDec 01, 2016Aspirant
Thanks. I do not use or plan in using Plex.
My question is about finding a firmware version 6.2.4 (the one used to upgrade from 4)
Where can I download previous firmware versions so I can hopefully revive the unit.
I will be happy with even a version OS 4.
Thank you
Thank you
- StephenBDec 02, 2016Guru - Experienced User
Downgrades from 6.6 to 6.2.4 aren't recommended. In general googling for the older releases works quite well... :smileywink: http://kb.netgear.com/app/answers/detail/a_id/27497
You might also need this procedure for that: https://community.netgear.com/t5/Using-your-ReadyNAS/How-to-downgrade-firmware-from-6-4-0-to-6-2-5-on-RN104-Please/td-p/1016511
There is some info on reverting to OS 4 here: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/m-p/859412
