Xibo's avatar
Xibo
PRO 6 doesn´t recognize disk in slot 1 #26379287
Hi guys,   I´m a happy Readynas-User since 2008. My first one- a Duo was replaced with an Ultra 4 and in 2013 I also bought a Pro 6. Both were running fine, but now I have an issue with the bigge...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jan 25, 2016
    Assuming the disk is inserted properly this would appear to suggest a hardware issue.
    If you open a support case please describe the tests you have done. Let me know your case number.
ProSupport for Business
