dsm1212
Dec 01, 2015Apprentice
Pro 6 upgrade to 6.4.1
FWIW I updated from 6.2.4 to 6.4.1 and had a few minor issues:
1. wordpress was no longer working. I hadn't used it much so I uninstalled for now, but if I had been a big wordpress user I might have been pissed.
2. My external USB drives got renumbered and this whacked all my backup jobs. The backup UI would not let me change the destination locations even though it said "no longer exists". So I found the mount config files (storage.conf and usb_map). I made the edits to restore the names to the drives (apparently the identifiers for the seagate externals is different than what it was on 6.2.4. The mybook I have attach preserved it's name.) Rebooted and the drives are back with the right names.
steve
- Supertramp11Luminary
Thanks Steve,
What about de fans. Are they keeping the device cool?
- dsm1212Apprentice
CPU is 1622 and system fan is 907. CPU is 37c and system is 64c. This is no change for me. I think the cpu cooler is overdue for a cleaning. The system temp has always been high even though I can't feel it anywhere near that hot at any point inside or out. So far so good.
steve
- Equinox1Guide
In my case, everything went smoothly.... however, I noticed that on my quad-core system, I only have 2 "thermometers" as temperature icons.
Netgear must have forgotten that there are some quad cores out there in the wild. :-)
It should be peanuts to put it back to report the right amount of cores. I hope.
