apoleon's avatar
apoleon
Pro Pioneer fan failed (?)
Hello!
I have a ReadyNAS Pro Pioneer Edition 6-bay NAS device, about 4.5 years old. Running constantly without any major probems (once, however, I had to move all data off and reformat the system due to many file issues).
I was away for one week, and during that time several odd problems arose:
There are entries in the log once about every 15 minutes saying:
Fri May 30 21:30:18 EEST 2014 (null) 1 (null) (SYS 0 rpm).
There are dozens of these.
Occasionally, there is a similar row with slightly different content:
Fri May 30 20:47:54 EEST 2014 (null) 1 (null) (SYS 81 rpm).
or
Fri May 30 16:31:53 EEST 2014 (null) 1 (null) [(null): 0-65C/32-149F, (null): 66.0C/150.8F].
When I go to Status > Health tab of the web UI it says:
Fan SYS 1757 RPM OK
Fan CPU 1939 RPM OK
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 22 C / 71 F [Normal 0-60 C / 32-140 F] OK
The CPU temperature seems oddly low, as I believe it is hotter here inside, altough I have not measured it. I've tried recalibrating and everything went fine.
Also, every once in a while (could be every 15 minutes, haven't measured), the device fans go into "turbo mode", similar to recalibration. The, after a while, they slow down again and the noise level drops to normal.
My device has all 6 bays full, each one with a 2 GB disk. The temperature of each disk is around 31 C / 87 F.
I'm running RAIDiator-x86 4.2.26, which is the most recent version at time I'm writing this.
Any ideas? To me it seems the SYS fan is failing/failed, although the Health tab does not indicate anything is wrong. If so, is it possible to replace it? I do have some experience in this kind of stuff, and I don't think I'll destroy anything if I do try to replace. Does anybody know which type/model fan I should buy, assuming this is indeed a fan issue and not simply a broken sensor/software issue?
I could not find a single post in this topic, so at least the problem is not very common.
ProSupport for Business
