clobberator
Feb 23, 2014Aspirant
Pro Pioneer Shuts Down, won't stay down.
I have a ReadyNAS Pro Pioneer, purchased some time ago, probably 5 years?
Anyways, aside from disk failures, it's been trouble free. Until recently - I try to power down the unit, but after a few moments, it turns itself back on. Don't have Wake-On-LAN enabled.
My procedure to shut it down - go to Frontview, System, Shutdown, "Shutdown and Turn Off Device," then click Apply. It spins down the disks, then the device goes silent.
Tried to reset to defaults, update RAIDiator, still the same. Here's some system log snippets:
Diagnostics:
Disks
* Disk 1 (model Seagate ST1000NM0011, serial number Z1N4B6AF) has 1 reallocated sectors. Reallocated sectors might be acceptable, but they are often the first warning sign that a disk is starting to fail.
Memory
Passed diagnostics.
Network
Passed diagnostics.
Performance
* Jumbo frames are disabled on interface 1. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
* Jumbo frames are disabled on interface 2. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
Volume
Passed diagnostics.
Enclosure:
temp!!1!!status=ok::descr=45.0C/113.0F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=16.5C/61.7F::expected=0-60C/32-140F
fan!!2!!status=ok::descr=2109RPM::type=CPU
fan!!1!!status=ok::descr=912RPM::type=SYS
ups!!1!!status=not_present::descr=Not present
volume!!1!!status=ok::descr=Volume C: RAID Level X2, Redundant; 3420 GB (92%) of 3683 GB used
disk!!1!!status=ok::descr=Channel 1: ST1000NM0011 931 GB, 33C/91F
disk!!2!!status=ok::descr=Channel 2: ST1000NM0011 931 GB, 34C/93F
disk!!3!!status=ok::descr=Channel 3: ST1000NM0011 931 GB, 33C/91F
disk!!4!!status=ok::descr=Channel 4: ST1000NM0011 931 GB, 32C/89F
disk!!5!!status=ok::descr=Channel 5: ST1000NM0011 931 GB, 34C/93F
disk!!6!!status=ok::descr=Channel 6: ST1000NM0011 931 GB, 33C/91F
model!!0!!mode=home::descr=ReadyNAS Pro::arch=x86
When I flip the power switch to the ON position, it doesn't spin up right away. Wait a few minutes, it turns on when it feels like.
This excessive power usage is bugging me, no point running it when nobody is home, so I had set up so that it would power off during the hours when nobody is around.
Thanks
Diagnostics:
Disks
Memory
Passed diagnostics.
Network
Passed diagnostics.
Performance
Volume
Passed diagnostics.
Enclosure:
Thanks
- clobberatorAspirantFixed this issue by swapping in a new power supply.
- berkut1Tutor
clobberator wrote: Fixed this issue by swapping in a new power supply.
I am having the same problem with my NAS Pioneer Pro failing to stay shutdown via either the web page or front panel.
I will go ahead and replace the power supply and cross my fingers that will do the trick.
Thanks for posting your problem & solution.
