MrBadger
Nov 02, 2016Aspirant
Probably power supply issue
I've read through a number of issues with the power supply failing on various models. I suspect that's what I have. My unit (ReadyNASRND4000) has been running fine for a number of years (5 according ...
- Nov 19, 2016Finally getting back to this. Disassembled the unit today. The back of the unit says ReadyNAS RND4000 v3. The PSU is internal (or was, it's external now since I disassembled it! :) ) After much casting about I've ordered a replacement PSU from Evercase in the UK: http://www.evercase.co.uk/PowerSupplyUnits.htm#ReadyNASPSU. $100 with shipping but the data is priceless. Assuming this works I'll be dumping everything to ... something... and then looking for a new (and faster) unit. Unless NetGear does something about the backward compatibility with disks in its newer units I'll be looking elsewhere. So please tell me that moving forward I can be assured of pulling disks from a unit and having them work in a newer unit (yeah, yeah, within reason of course - but there's no reason that my 5 year old 2T drive should not be supported.) So, enough bitching and whining. When the new PSU arrives I'll update with what happened.
Nov 02, 2016Guru - Experienced User
Can you tell us if it a v1 or a v2 NAS? Please read this link - the labels ARE misleading. http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Warranty of the NV+ v1 was generally 5 years, so check your purchase date right away to see if you are still covered.
The service action only applies to a specific range of serial numbers on the v1. I suspect your NAS is to new, but the serial range is quoted below:
A small percentage of ReadyNAS NV (revision B) and NV+ owners with low-noise fanless power supply unit (PSU) may encounter a premature failure of the PSU due to elevated temperature. The ReadyNAS systems affected have Serial numbers between 000DA2010FFE and 000DA2016000.
The warranty of the NV+ v2 was 3 years, and the service action did not apply. So if you have a v2, you'll need to get another NAS.
Note that all of the current NAS are faster and have more features.
MrBadger
Thanks, I'll check when I get home and have the unit in front of me.
Is there anything I should be aware of getting a new NAS unit with respect to compatibility for my existing drives and their format? Can I just plug in my existing drives and expect a new unit to sort things out? Or...?
- StephenBNov 02, 2016Guru - Experienced User
You won't be able to migrate the disks. This link should give you an idea on how it's done: http://kb.netgear.com/app/answers/detail/a_id/29876 Note support will charge, you'll have to ask them how much.
It is possible to jury-rig a stock ATX supply to work with the NV+. On the NV+ v1 you need to rework a cable, not sure what you'd do with a v2. You could make the cable change on a 24 pin extender cable, and not modify the temporary supply. It likely wouldn't fit into the case, but it could run externally. Anyway, that's potentially another path for data migration.
- MrBadgerNov 02, 2016Aspirant
OK, I'll do what is necessary. But... I have to note that as an enginner I'm ASTOUNDED that there is not a way to easily migrate disks to a new system. I would think this would be a use case that was considered and accomodated early in the process. So I guess I need to look up some of those alternate power supply solutions I saw floating around the web. :(
Please do confirm what NAS model you have.
