rlapt
Feb 02, 2018Tutor
Problème de suppression de partage
Bonjour, J'ai un ReadyNAs Duo assez ancien, mais pour mon utilisation (sauvegarde secondaire de des disques une fois par mois), il convient très bien. Je rencontre 2 problèmes. PB 1: J'a...
- Feb 08, 2018
wrote:
Do you that the best solution is to put it this NAS in the bin ?
It is aging, and of course you will need to replace it at some point. The equivalent now is the RN212, which is 4-5x faster.
But you could try copying off all the data, and then do a factory reset. Then reconfigure the NAS and restore the data from the backup.
rlapt
Feb 08, 2018Tutor
Hi Stephen,
Many thanks for your answer.
I updated the firmware, but all the things are still the same.
The transfert rate is now slow (2 MO/s for files of 3 MO) and the erase speed is always 20 files/s.
I have always the problem described in my first post :
I suppressed a sharing volume last year and it has disappear on the web interface but is still visible and usable on the file explorer of Windows.
Regards
Feb 08, 2018Guru - Experienced User
- rlaptFeb 12, 2018Tutor
Many thanks.
I will try your solution, but I expect nothing better.
