chsu83
Dec 27, 2019Luminary
Problem - home folders not correct anymore - asking for encryption key
First: - disabled the X-RAID - to add a Disk & Create a new second encrypted Volume for a complete backup - named that volume backup8tb - more or less "rsync -av /data /backup8tb" - EXPORTED the...
chsu83
if I re-plug the disk with the backup8tb volume
the messages
"It is not recommended to mix different disk types. Current volume is using Unknown drives. Please replace the disk in channel 4 (Internal) to match the rest of the disks on volume backup8tb for best performance."
"Disk in channel 4 (Internal) changed state from RESYNC to ONLINE."
chsu83
....and apps are also not installed anymore
- StephenBDec 27, 2019Guru - Experienced User
Can you download the log zip file, and copy/paste mdstat.log here?
- chsu83Dec 28, 2019Luminary
- StephenBDec 28, 2019Guru - Experienced User
chsu83 wrote:
sure
https://1drv.ms/u/s!AlObG0fKU4SSvWH-CTVrcbK3sy4E
This shows just one volume (with 5 disks) - no sign of backup8tb. The OS partition is degraded (it does say it is supposed to have 6 disks).
Is ssh enabled? I'm wondering if what is in /data/.apps
