tradtke's avatar
tradtke
Problem After upgrade to 6.73. TFTP_REQ
We have a 4220 ReadyNas whtat we upgraded from 6.5.1 to 6.73.
After the upgrade the RAIDr shows status as TFTP_REQ.
We tried the USB recovery
Tried the USB recovery a 2nd time with 6.74 (according to Netgear the 6.73 was not out there long for a number of buggy reasons).
Still boots up to the Raidr screen but ultimatly says in the status line: TFTP_REQ.
Tried the factory restet.... to no avail.  The product was functioning perfectly until the upgrade.
Now we cant get it up and are lookng for any insights to turn our boat anchor back into a function member of our IT infrastructure.
Any help would be greatly appreaiated.
  • StephenB's avatar
    Try disconnecting everything from the USB ports and see if that will reboot.
    • tradtke's avatar
      tradtke
      After the USB recovery the system shuts down as is supposed to according to the directions.  We then pull the USB drive so no USB is plugged into the NAS, power on the unit. It boots but ultimatly settles into the RAIDr showing the status: TFTP_REQ
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    So you don't have a DHCP server on your network?
    In the TFTP_REQ state local telnet is active.
    • tradtke's avatar
      tradtke
      No DHCP Server on the network that the 4220 is on.  We can put one up if that offers a path to a potential solution. (Or a TFTP server for that matter).
ProSupport for Business
