danieleb001's avatar
danieleb001
Problem with an old Readynas2000
Hello everybody,
This week my Readynas2000 notified me problems with power supply. messages I got were relòated to poversupply between 10,5V instead of 12V.
I tried to fix it replacing the external power supply with a new one, but without any luck.
I need to recover my data stored in the raid1 disks
There is any way to have this done?
I tried to restore via network, but systen after few minutes automaticcaly switch off.
I'm 99.99999 sure HDs are still operational and data are still there (I tried to see them via trials of EasUS and reclaime.com)
I removed both drives and I tried to recover data directly from the disks, but due the fact that data looks stored in a linux file system I don't know how sort this out.
There is anyone able to advise me on how retrieve my data?
Thanks in advance for all your support
Kind regards
Daniele
  • If you decide to get a used replacement, make sure you do get a compatible one.  You said you have a "ReadyNAS 2000", but there are a lot of models that have a 2000 number.  There is the original Duo (RND2000-100), the Pro2 (RNDP2000-100), Ultra2 (RNDU2000-100), and Duo V2 (RND2000-200).  Only the Pro2 and Ultra2 are compatible with each other.  And if you have a Duo, Netgear used "V2" in two different ways.  Most of the "V2" systems I see for sale on eBay are really V1's.  The best way to tell these all apart from a listing is to look at the back.  Fan size and number of ethernet ports are what to look for.  Duo V1, small fan (also recessed power jack).  Duo V2, large fan and one network port.  Pro2 and Ultra2, large fan and two network ports.  Of course, you could also upgrade to a compatible unit with more bays (where the list gets even more complicated)
  • With RAID1, you can recover from just one drive.  You may be able to accomplish that running the NAS with just one because the load on the +12V will be less.  Try powering down and then booting with just one.   Note that once you have done that, it is best to not put both back in at the same time, at least until you have recovered the data, as they may be out of sync with each other.
    • danieleb001's avatar
      danieleb001
      Thanks a lot for your answer. I'm working now to acomplish this part.
      There is probably another problem with the nas. looks unable to present me the administrtative screen. I think something else is broken inside.
      I'm trying now ro connect the NAS via a cross cable tomy PC to avoid any networking issue.
      I'm also looking to buy another readynas of the same age of the my defective one, to see if I can use it to recover my precious data.
      I'm sure data are still there.
      Do you know if I install one of the 2 disks in a brand new Netgear Readynas, I'll be able to recover my data?
      Thanks for your support, really appreciated
      Daniele
      • StephenB's avatar
        Connect disk 1 to a windows PC, and use a free utility called R-linux for windows. ( http://www.r-tt.com/free_linux_recovery/ ).   That takes the NAS itself out of the equation.  Unlike ReclaiMe, it is completely free (though it simply reads a healthy file system, it doesn't try to recover data from a corrupted file system as ReclaiMe does).
        You do not need a cross-over cable, as gigabit ethernet auto-detects that and compensates.  https://kb.netgear.com/21414/How-do-I-direct-connect-between-ReadyNAS-and-PC-Mac
ProSupport for Business
