guigui_bebert
Jul 13, 2016Guide
Problems with directly uploading file from link without local download
Hello, I would like my NAS to download a file to a folder using an HTTP Link without having to first downloading it locally. Just like with a torren client I would like my RN104 to download a...
JennC
Jul 16, 2016NETGEAR Employee Retired
Hello guigui_bebert,
If there server where the files will coming from has an option to connect or be copied to DropBox, can you check this DropBox will work? The idea of the DropBox is whatever file you copy to your DropBox account will be stored to anywhere you have installed DropBox application, that includes NAS if it has the app too.
guigui_bebert
Jul 17, 2016Guide
Hello JennC,
Thanks for your reply.
As a matter of fact the editor does not provide a dropbox option. Furthermore, the files in question were zipped part archives, totalling about 20Go.
As i said, I know there are many workaround to a problem like this (one of wich I used) but since I might encounter that same problematic I wanted to know if such a feature existed.
And next time I might be abroad and only able to connect with my smartphone.
Therefore a simple download from HTTP/set the NAS as a target would have been simpler.
From what I understand there is no app/functionality that would cover my needs.
thanks anyway for your time.
Guillaume
