sunsina
Dec 28, 2014Guide
Pydio6 is already avaliable but not portable to OS 6.2.2
I upgraded my readynas to OS v6.2.2, then I installed the PyDio through Apps, in this OS version it only installs PyDio v5.2.3. While PyDio6 is for several weeks out with major improvements, I tried ...
sunsina
Mar 04, 2015Guide
Thanks for your new pydio package
infact I could not install it on readynas OS.6.2.2
and i get following error
Would you mind let me know how can I solve this issue?
Thanks
# dpkg -i pydio_6.0.1_all.deb
(Reading database ... 29994 files and directories currently installed.)
Preparing to replace pydio 6.0.1 (using pydio_6.0.1_all.deb) ...
--2015-03-04 09:48:30-- http://www.dotdeb.org/dotdeb.gpg
Resolving http://www.dotdeb.org (http://www.dotdeb.org)... 195.154.242.153
Connecting to http://www.dotdeb.org (http://www.dotdeb.org)|195.154.242.153|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5299 (5.2K) [application/octet-stream]
Saving to: ‘dotdeb.gpg.3’
dotdeb.gpg.3 100%[===============================================================
2015-03-04 09:48:31 (106 MB/s) - ‘dotdeb.gpg.3’ saved [5299/5299]
OK
Unpacking replacement pydio ...
dpkg: dependency problems prevent configuration of pydio:
pydio depends on php5-gd (>= 5.6); however:
Version of php5-gd on system is 5.4.36-0+deb7u3.
pydio depends on php5-pthreads; however:
Package php5-pthreads is not installed.
dpkg: error processing pydio (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
pydio
Thanks
