sunsina
Dec 28, 2014Guide
Pydio6 is already avaliable but not portable to OS 6.2.2
I upgraded my readynas to OS v6.2.2, then I installed the PyDio through Apps, in this OS version it only installs PyDio v5.2.3. While PyDio6 is for several weeks out with major improvements, I tried ...
mrmilo
Jul 16, 2015Tutor
I'm on 6.2.4 now and the problem is still the same
Any way to update php manually? I would like to replace Owncloud with Pydio.
Thanks
/apps# dpkg -i /data/Documents/pydio_6.0.1_all.deb
(Reading database ... 32256 files and directories currently installed.)
Preparing to replace pydio 6.0.1 (using .../Documents/pydio_6.0.1_all.deb) ...
converted 'http://www.dotdeb.org/dotdeb.gpg' (ANSI_X3.4-1968) -> 'http://www.dotdeb.org/dotdeb.gpg' (UTF-8)
--2015-07-16 20:18:58-- http://www.dotdeb.org/dotdeb.gpg
Resolving www.dotdeb.org (www.dotdeb.org)... 195.154.242.153
Connecting to www.dotdeb.org (www.dotdeb.org)|195.154.242.153|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5299 (5.2K) [application/octet-stream]
Saving to: 'dotdeb.gpg.6'
dotdeb.gpg.6 100%[===========================================================>] 5.17K --.-KB/s in 0s
2015-07-16 20:18:58 (114 MB/s) - 'dotdeb.gpg.6' saved [5299/5299]
OK
Unpacking replacement pydio ...
dpkg: dependency problems prevent configuration of pydio:
pydio depends on php5-gd (>= 5.6); however:
Version of php5-gd on system is 5.4.41-0+deb7u1.
pydio depends on php5-pthreads; however:
Package php5-pthreads is not installed.
dpkg: error processing pydio (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
pydio
Thanks
Retired_Member
Sep 02, 2015Hello,
I have the same issue, I followed the discussion tried what's on it, and I'm still unable to install Pydio 6.0.8 on a ReadyNAS 516 OS 6.2.4.
Any ideas?
In advance, thank you!
Best.
- Retired_MemberSep 04, 2015
I have succesfully install php 5.6, but I still can't install Pydio
root@Grp-M_NAS:~# php --version PHP 5.6.12-1~dotdeb+7.1 (cli) (built: Aug 8 2015 01:28:25) Copyright (c) 1997-2015 The PHP Group Zend Engine v2.6.0, Copyright (c) 1998-2015 Zend Technologies with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2015, by Zend Technologies
