pofrani
Apr 27, 2012Aspirant
Question about resetting
Hi all, I want to know - I have a readynas duo with 2x 1tb seagate drives. I have read that if I pressed the reset button on the back for more than 10seconds, it will do a complete factory reset (...
Apr 27, 2012Guru - Experienced User
I don't think that will work. I suspect the duo will sync the 2nd drive to the first one (which is not what you want).
I am wondering why you want to do a factory reset?
