mdgm-ntgr
May 30, 2011NETGEAR Employee Retired
Question about storage node
Just had a read of Integrating Acronis with ReadyNAS. This is interesting. It sounds interesting. I'm curious as to why a storage node is needed to allow deduplication? Why can't a backup direct to th...
Mace_Windoo
Aug 02, 2011Aspirant
Hi guys,
Deduplication is a great way to save space when backing up data and it also helps minimize the amount a internet traffic required to move data to a secondary location when using "ReadyNAS Replicate" between devices. However, with efficiencies come some overhead.
The Storage Node server in an Acronis solution is tasked with the responsibility of calculating what data is unique and what data is common. The storage node server holds a database of all checksumed data, which it uses to make the decision on which data can be ignored and which data is new and unique, everytime a backup runs. The storage node also makes the decision on which data within a Vault (example: ReadyNAS Pro Family) is no longer needed within a vault (pruning operation).
This means all the agents on your servers need to pass data to the storage node first before they are written to the NAS and when it does get written, it will save you lots of space.
