risiman
Apr 25, 2017Star
RAID 1 Issue - Volume Degraded after HDD replacement
I hava ReadyNAS 104 with firmware 6.6.1. Inside it I had 1 TB, 1TB, 3 TB and 6 TB HDDs, the two first configured as RAID 1. I had a RAID 1 with 2 HDD of 1TB, but one of them stop working. While ...
jak0lantash
Apr 25, 2017Mentor
I would unslot sde and reinsert it. This should trigger a new resync attempt and hopefully end up cleaning the RAID array.
Otherwise, manually operation may be necessary.
You should also consider backing up your data.
