DannielJ
Jul 22, 2017Aspirant
RAID5- Data degraded (data innaccessible) then Volume disapeared after reboot
Hello, When I came back from home, my nas displayed "DATA degraded" on the screen. As I could not access the data, I tried rebooting it, but without success, the data degraded is not showing anymore...
JennC
Jul 24, 2017NETGEAR Employee Retired
Hello DannielJ,
Unfortunately, ATA error is not good, it is more worisome that you have 2 disks getting this error message. I strongly suggest to contact support team asap. This may need data recovery, if data is still recoverable.
Welcome to the community!
- DannielJJul 25, 2017Aspirant
Hello, Thank you for your answer, it is indeed strange that both failed at the same time.
I have checked the logs and the error never happened on any of the disks before.
How do I contact the support team please ?
- JennCJul 25, 2017NETGEAR Employee Retired
Hello DannielJ,
You may visit https://my.netgear.com/registration/login.aspx and login, this will allow you to register your product and/or show you the available support channels for it.
Thanks, I have registered my product, I guess i have to pay to have the support ?
