whitebear_99's avatar
whitebear_99
Raid5 is broken and separate raid0 and raid1?
I made the raid5 with 6 disks and used for a year.
Now I my RN316 is broken then I try to connect these disks to another linux.
However I checked every disks, somehow there is raid0x5disks and raid1 x 1disk
It looks like raid5 fall aparts into raid0 and raid1.
Is it possible to use these as raid5 forcebly??
such as 5 drives,
/dev/sdd3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 5cda431d:eb21dd6d:849d9d92:636a0c72
  Creation Time : Wed Jun 11 08:24:46 2025
     Raid Level : raid0
   Raid Devices : 5
 Avail Dev Size : 15618351694 (7447.41 GiB 7996.60 GB)
    Data Offset : 264192 sectors
   Super Offset : 8 sectors
   Unused Space : before=264112 sectors, after=0 sectors
          State : clean
    Device UUID : 6ac2adc5:992e062a:7e8aa6d7:5885b27a
    Update Time : Wed Jun 11 08:24:46 2025
  Bad Block Log : 512 entries available at offset 8 sectors
       Checksum : d77027db - correct
         Events : 0
     Chunk Size : 64K
   Device Role : Active device 1
   Array State : AAAAA ('A' == active, '.' == missing, 'R' == replacing)
one drive is like this,
sudo mdadm --examine /dev/sdf3
/dev/sdf3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 38792c55:ec30a05d:ef132979:1abc74c9
  Creation Time : Wed Jun 11 07:15:43 2025
     Raid Level : raid1
   Raid Devices : 1
 Avail Dev Size : 15618351680 (7447.41 GiB 7996.60 GB)
     Array Size : 7809175808 (7447.41 GiB 7996.60 GB)
  Used Dev Size : 15618351616 (7447.41 GiB 7996.60 GB)
   Unused Space : before=263912 sectors, after=64 sectors
          State : clean
    Device UUID : df652525:c37b0a23:214456ea:deba215a
    Update Time : Thu Jun 12 02:46:05 2025
  Bad Block Log : 512 entries available at offset 264 sectors
       Checksum : 295491c1 - correct
         Events : 2
   Device Role : Active device 0
   Array State : A ('A' == active, '.' == missing, 'R' == replacing)
Swap area(/dev/sd*2) somehow keep raid10
 sudo mdadm --examine /dev/sdf2
/dev/sdf2:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 860482db:bc8f628a:3b14dc96:8fc010a0
     Raid Level : raid10
   Raid Devices : 6
 Avail Dev Size : 1044480 (510.00 MiB 534.77 MB)
     Array Size : 1566720 (1530.00 MiB 1604.32 MB)
    Data Offset : 4096 sectors
   Unused Space : before=4016 sectors, after=0 sectors
          State : clean
    Device UUID : 7300c357:529e4410:a14c33fc:e11bb3c2
    Update Time : Wed Jun 11 17:09:12 2025
  Bad Block Log : 512 entries available at offset 16 sectors
       Checksum : a8d95fb5 - correct
         Events : 19
         Layout : near=2
     Chunk Size : 512K
   Array State : AAAAAA ('A' == active, '.' == missing, 'R' == replacing)
  • Based on what you have posted (you didn't post anything regarding the other drives), I believe your volume is named FILES, not data.  The arrays shown are FILES-0 and FILES-1, and I suspect the others make up what is still called FILES.  Since there cannot be more than one array with the same name, that's how they would be broken up if the OS can't figure out how to assemble them as one.
    You may be able to forcibly assemble the array from SSH, but let StephenB​ take a look at your logs to make sure you do it right.  There could be some file corruption, however.  If that won't work, then recovery software might, but it's not cheap; so give StephenB​ a shot first.
    • whitebear_99's avatar
      whitebear_99
      There is /FILES however this directory is empty.
      If possible could I ask about this how to force assmble? for next attempt.
      • StephenB's avatar
        I am also seeing a couple of references to a /Second path in your logs.  Did you set up another volume?  (perhaps the sdg USB drive???)
  • StephenB's avatar
    whitebear_99 wrote:
    Now my RN316 is broken
    Can you give us more information on how it failed?
      whitebear_99
      Suddenly,  `/data/` was vanished. and user home data also deleted.
      • StephenB's avatar
        Loss of the volume is usually disk related (though it can also be triggered by a software crash or power cut).  Likely nothing is wrong with the NAS hardware.
        One option is to power down the NAS, reinsert the drives, and power up.  Then get a full log zip file from the logs page.  That will give useful info on what went wrong.
        The logs would give me the information I asked for on the other thread.  (As I noted there, please keep this on one thread going forward).
        If you want me to look at the logs, then put the full zip in cloud storage (drop box, google drive, etc), and send me a private message (PM) with a link.  Make sure the permissions are set so anyone with the link can download.  You send a PM using the envelope icon in the upper right of the forum page.
ProSupport for Business
