Terraterm
Oct 24, 2017Aspirant
Raidar not detecting device
Hello Raidar does not find the device. Firewall and AV, are off. I can ping and access thru the browser. also changed pwd thru the browser interface. I can't see any other menu's in the br...
Oct 25, 2017Guru - Experienced User
This is an NV+ v1? What firmware is it running? What browser are you using?
When did you first begin seeing this issue?
- TerratermOct 25, 2017Aspirant
problem resolved.
java needed updating
as for Raidar version 4.3.8 detects it, not 6.3.
firmware 4.1.6
Browser Waterfox
- StephenBOct 25, 2017Guru - Experienced User
Terraterm wrote:
firmware 4.1.6
That is extremely old. I suggest updating it to 4.1.16. You'll likely need to manually install it (I think the update server URL has changed since 2009). https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
i thought the version number was up to date, I had not seen the extra 1, in the version number.
Thx!, for pointing it out.
Regards
