Terraterm
Oct 24, 2017Aspirant
Raidar not detecting device
Hello Raidar does not find the device. Firewall and AV, are off. I can ping and access thru the browser. also changed pwd thru the browser interface. I can't see any other menu's in the br...
Terraterm
Oct 25, 2017Aspirant
problem resolved.
java needed updating
as for Raidar version 4.3.8 detects it, not 6.3.
firmware 4.1.6
Browser Waterfox
Oct 25, 2017Guru - Experienced User
Terraterm wrote:
firmware 4.1.6
That is extremely old. I suggest updating it to 4.1.16. You'll likely need to manually install it (I think the update server URL has changed since 2009). https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
- TerratermOct 25, 2017Aspirant
i thought the version number was up to date, I had not seen the extra 1, in the version number.
Thx!, for pointing it out.
Regards
