netracer
Sep 14, 2012Apprentice
RALUS Agent problems
As I've been beating my head through this forum for hours looking for a solution, I concede its time to ask for help. I am trying to use my readynas 4200 as a backup target for my Backup Exec Server....
arminvanbuuren
Sep 24, 2012Tutor
Maybe i find a temporary solution. I use v12.5.3 and it works by editing the ralus.cfg file on the nas system. ( you must install the ssh addon)
My jobs complete successfully for the moment since I change it :
Try these steps -
- Stop the RALUS service by running the command "etc/init.d/VRTSralus.init stop”
- Run the command "vi /etc/VRTSralus/ralus.cfg”
Find the line which says “Software\Symantec\Backup Exec for Windows\Backup Exec\Agents\Agent Directory List”. Check if there are two entries of these .If not add the following entries using the VI editor. ( before editing you can do a backup of the ralus.cfg config file : " cp ralus.cfg ralus.cfg.ori " )
Software\Symantec\Backup Exec for Windows\Backup Exec\Agents\Agent Directory List 1=<media server IP>
Software\Symantec\Backup Exec for Windows\Backup Exec\Agents\Agent Directory List 2=<media server NAME>
After adding the above entries, start the RALUS service run “etc/init.d/VRTSralus.init start”
And Please re-check.
Try these steps -
