ovrdrvn
Aug 15, 2016Aspirant
Can't Mount SMB/CIFS Shares in OS X Sierra Public Beta 4
Latest firmeware 4.4.28 and I suspect it's a Sierra issue but I see the drive and shares and am promtped to authenictate which seems to work. Trying to mount or view files results in a time out. Driv...
GJSchaller
Sep 22, 2016Guide
Hmmm... now I am being told AFP was *not* removed in macOS Sierra:
ovrdrvn
Sep 22, 2016Aspirant
Apologies as I knew that. It wasn't removed. The only difference between you and I seems to be that you can browse via SMB and I can't. I can authenticate to both protoclos and see directories but never see any files.
- GJSchallerSep 22, 2016Guide
Yeah, the commenter on the Apple Discussion boards was talking out of his butt, so that was bad information. Argh....
The consistent thing I am seeing is a problem with Authentication... AFP forces me to manually reconnect and authenticate each time I want to mount a share. Time Machine never asks me for credentials, and just fails when trying to connect, presumably because it can't authenticate. This does sound more like a bug, and less like intentional.
ovrdrvn - try removing all references to authentication to your NAS from your Keychain, see if that clears it up and lets you reconnect, at least by hand?
