spicedrive
Mar 01, 2018Aspirant
Disaster on a readynas 314 - need advice please
Going to simplify this - essentially this is all because of the 6.9.2 update causing NAS to not boot up after update. Not happy. I had 2 x 3TB drives as RAID1 in a 4 bay NAS. I installed a new 3TB...
mdgm-ntgr
Mar 05, 2018NETGEAR Employee Retired
The safe mode in 6.9.3 should just make it easier to diagnose as it would boot up into a state where you could do things like check the SMART stats.
Your logs show that the disk in drive bay 4 has a current pending sector count of 37.
It's important to check your disk health before adding a disk or replacing a disk.
You should contact support.
spicedrive
Mar 05, 2018Aspirant
mdgm,
I've contacted support 4 times and tbh, I repeat myself everytime and haven't really got anywhere at all.
I will continue at it but was hoping to ask, whether you think reinstalling the OS on just the 3 drives is any use.
- mdgm-ntgrMar 06, 2018NETGEAR Employee Retired
Let me know your case number and I can arrange for your case to be reviewed.
No. Re-installing the OS only helps in some rare cases where installing the OS over the top of itself and/or resetting some network settings and the admin password would resolve a problem.
- spicedriveMar 08, 2018Aspirant
Thanks MDGM.
I ended up finding out the original order of the 3 drives (support told me this was important), I didnt know. Put the drives back in and boot menu'ed (with extreme difficulity), finally getting it to boot the original degraded RAID5 volume. I let it resync, and it worked.
I am now in the process of copying a million+ files onto the new HDD to make a backup (so not out of the woods yet).
The only issue I had now was I tried to copy a 1TB folder using the web interface (which seems to be buggy) and while it was copying I was trying to change a different shares name where it errored. I had to restart the NAS.
Anyway I have lost two shares now off the original RAID5 volume. They have just disapearred but the data usage is still there in the volume information. I cannot access via web interface or my windows mapping. Any ideas?
- mdgm-ntgrMar 08, 2018NETGEAR Employee Retired
Seeing you're working with support it's probably best to continue working with them.
If you let me know your case number I can arrange for your case to be reviewed.
